TwinTurbo.NET: Nissan 300ZX forum - Re: not sure if bad wastegate, solenoid is causing hesitation
Subject Re: not sure if bad wastegate, solenoid is causing hesitation
Posted by Stadsport (PHX) on March 08, 2010 at 11:55 AM
  This message has been viewed 215 times.
In Reply To not sure if bad wastegate, solenoid is causing hesitation posted by blackice98 on March 08, 2010 at 12:30 AM
Message I doubt it's from the wastegate solenoid, those don't fail nearly
as often as any of the many other things that cause hesitation.
Besides, did you see your boost pressure drop with the
hesitation?
Fix those circuit codes before you move on...
