TwinTurbo.NET: Nissan 300ZX forum - no, performance will be the same at a given psi
aliaZ
on March 06, 2010 at 9:15 AM
if u set the 500's to 8psi,will that effect the performance?
posted by SuparexTT
on March 05, 2010 at 11:41 AM
the drawback of setting your base boost lower is that you will have lower maximum available boost. If you don't regularly run race gas this isn't an issue
boost level w/ no stock solenoid, boost controller off
Paulym1111
17:14:04 03/03/10
I believe sport 500's are preset to 12 psi (n/m)
aliaZ
19:11:12 03/03/10
It's true, 12 psi (n/m)
zellamay
20:33:00 03/03/10
SuparexTT
11:41:11 03/05/10
Are you asking if 8 psi will produce less power than 12 psi?
zellamay
19:00:47 03/05/10
no, performance will be the same at a given psi -
aliaZ
09:15:00 03/06/10
thanks!
Paulym1111
21:50:24 03/03/10
