TwinTurbo.NET: Nissan 300ZX forum - For the horn pull the connector off and apply 12v+ to>>
Subject For the horn pull the connector off and apply 12v+ to>>
Posted by ZUL8TR on March 04, 2010 at 8:49 AM
  This message has been viewed 314 times.
In Reply To Horn and Third Brake Light do not work posted by LeaninBack916 on March 04, 2010 at 12:06 AM
Message it. That will bypass all fuses and switches. If it blows than the problem is not the horn. On my 92 na the horn is on the drivers side at the front air dam. To do test probably easier to remove horn andf apply 12v+ to connector while the body is negative or grounded.
For the 3rd brake light since you say they all do not work but the Iassume the lower brake lights do work I suspect a connector issue or bad ground. Need to open up the lid panal and check the connector and ground.
ZUL8TR in Orlando,FL
