TwinTurbo.NET: Nissan 300ZX forum - Stale gas has a very distinct smell. If not familiar with>>
Subject Stale gas has a very distinct smell. If not familiar with>>
Posted by ZUL8TR on March 04, 2010 at 5:31 AM
  This message has been viewed 149 times.
In Reply To Re: How old is that fuel? If ethanol sits the water will >> posted by ouikikazz on March 03, 2010 at 01:16 PM
Message the smell just wiff some fresh gas to have a relative comparison. Zees hate cold weather. Heae is a thought when the weather gets warm enough to work unplug the filter at the IN side from fuel tank and add a piece of hose to that loose hose end and run it to a bucket. To catch fuel crank engine for about 5 seconds rest then another 5 sec crank . Look for particles and also the smell. If not free of particles that is a bad sign and tank and fuel lines need to be cleaned. I would remove as much fuel as you can from the tank rather than adding any stabilizer. Stabilizer will not make bad fuel better it keeps good fuel from going bad.
You can hope the intake screens on the injectors are not clogged.
If the fuel pressure test fails check the regulator and modulater for leaking diaphrams by seeing if they hold vacuum.
ZUL8TR in Orlando,FL
