TwinTurbo.NET: Nissan 300ZX forum - manual boost controller install and wastegate solenoids
Subject manual boost controller install and wastegate solenoids
Posted by surfer31337 on March 03, 2010 at 1:27 AM
  This message has been viewed 3473 times.
Message hello,
i just installed my hallman MBC and i left the wastegate control solenoids in place. when i unplugged their connectors, the car now boosts at 7 psi (the MBC is still in its fully open position). now the car boosts at 7 psi. can you please confirm that my understanding is correct?
i propose the factory wastegates actuators actually start to open at 7 psi and assuming there is no "safety boost" condition, the solenoids close a little bit to fool the actuator into opening at 10 psi. my target boost goal is 15 psi. now the solenoids are unplugged (permanently open) so the MBC has to +8 psi instead of +5 psi. is all this correct?
if i'm right then everything is fine and i'm ready to start turning up the boost. BTW i monitor the ECU readings with my OBDI cable and there haven't been any trouble codes or detonation.
TIA.
