TwinTurbo.NET: Nissan 300ZX forum - Re: clutch disengaging itself
Subject Re: clutch disengaging itself
Posted by paintballkustoms on March 01, 2010 at 11:27 AM
  This message has been viewed 82 times.
In Reply To clutch disengaging itself posted by jj250ex on February 28, 2010 at 10:50 PM
Message i had this same problem on a z when the slave cyl was leaking not bad at all either which is why i was so confused. took 4-5 months of constant driving to drain fluid to low before a refill and caused a similar problem i would jack the car up and check to see if the slave is leaking it will show up on the bottom of the transmission on the front.
or of course what audioquest said.
