TwinTurbo.NET: Nissan 300ZX forum - Re: I had a coolant leak directly above Cyl #6..... well
Subject Re: I had a coolant leak directly above Cyl #6..... well
Posted by paintballkustoms on March 01, 2010 at 11:22 AM
  This message has been viewed 106 times.
In Reply To I had a coolant leak directly above Cyl #6..... well posted by BrianTT(Tpa,Fl) on March 01, 2010 at 09:22 AM
Message be a little more specific as to where the coolant leak was coming from and to be honest the only way to know for sure is to run it (after you remove debris via shop vac or removing the head). and sounds to me like it was just coolant seeing as to it had RUST. rust generally wont happen unless moisture is present in the environment (coolant leak) and after a few good combustions on that cyl the rust would be gone does that help any ?
