TwinTurbo.NET: Nissan 300ZX forum - I had a coolant leak directly above Cyl #6..... well
Subject I had a coolant leak directly above Cyl #6..... well
Posted by BrianTT(Tpa,Fl) on March 01, 2010 at 9:22 AM
  This message has been viewed 100 times.
Message I fixed the leak and then had a miss fire on one of the cylinders! I took the plugs out and the plug for #6 had dirt/sand/rust around the base and looked pretty bad! Could the water from the coolant leak get pass the coil pack and soak the spark plug and coil causing the miss fire?
