TwinTurbo.NET: Nissan 300ZX forum - Yes - this is certainly an acceptable way to try and fix
Subject Yes - this is certainly an acceptable way to try and fix
Posted by jzack on February 28, 2010 at 9:56 PM
  This message has been viewed 93 times.
In Reply To Hard wiring headlights? posted by Letterdawg on February 28, 2010 at 09:12 PM
Message this issue. I personally would try to salvage as much of the original system as possible -- just reduces the amount of work.
If the headlamp relays look to be working fine (ie., activating the cabin controls causes them to click) -- I'd think about trying to use them as part of the new circuit. If the control signal for the relays is working use that circuit connection to activate a replacement relay.
Basic two things you'll need to plan out this project is the car's circuit diagram and a digital voltmeter. Once you've determined which part of the car's lighting circuit isn't working - add the new circuit to replace it...
Do your parking lights work? That would be another way to get headlights ON. Wire a relay into one of the parking lights and when they go on so would the lo beam lamps. Not exactly OEM tho...
