TwinTurbo.NET: Nissan 300ZX forum - Compression test will not necessarily reveal if CO gas is >>
Subject Compression test will not necessarily reveal if CO gas is >>
Posted by ZUL8TR on February 28, 2010 at 7:59 AM
In Reply To Re: At 1.2 bar the system will get to that pressure if >>> posted by WazTTed on February 27, 2010 at 04:29 PM
Message getting into the coolant. Have you checked the radiator as I suggested? Before replacing parts you should do and the radiator test I suggest and feel for any cool spots, this is a no cost test. Also before replacing parts I would do a CO test done at a radiator shop still mich cheaper and less work than parts replacement and they will also check out the rest of your system as well as the radiator feel test (if not tell them to). Sometimes a clogged radiator is not easily unplugged without taking tanks off having core boiled and rodding the core coolant channels out.
ZUL8TR in Orlando,FL
