TwinTurbo.NET: Nissan 300ZX forum - Boost leak tested and will Not hold any pressure
Subject Boost leak tested and will Not hold any pressure
Posted by blackice98 on February 28, 2010 at 12:10 AM
  This message has been viewed 98 times.
Message hey whats up. i plugged up my intake with a 3" end cap and put a valve stem thru it. Now i tried using a low power air compressor and a hand pump and am not able to get any air pressure inside the piping. I hear no loud leaks, or any at all. I had the air compressor pump on for about 3 minutes unplugged it, and pressed the valve seal pin in and there was no air pressure. i tightened a lot of my hose clamps under the bumper and under the hood that are accessible.
The tester is not leaking and i havent heard any leaks. Anyone have any suggestions? Im thinking about getting it smoke tested, not sure where though. any suggestions would be appreciated.
