TwinTurbo.NET: Nissan 300ZX forum - Re: Transmission
Subject Re: Transmission
Posted by txq45 on February 27, 2010 at 8:12 AM
  This message has been viewed 87 times.
In Reply To Transmission posted by MyDreamZ on February 27, 2010 at 12:12 AM
Message The procedure is almost identical. You do have to remove the shield and remove the bolts that hold the torque converter to the flywheel to remove the trans. You also have more wiring which is mostly disconnected on the inner fender by the PS reservoir (3)
