TwinTurbo.NET: Nissan 300ZX forum - Re: Yep - just pull the injector connector plug. Depending on
Subject Re: Yep - just pull the injector connector plug. Depending on
Posted by Jiro on February 25, 2010 at 11:37 PM
  This message has been viewed 215 times.
In Reply To Yep - just pull the injector connector plug. Depending on posted by jzack on February 25, 2010 at 11:19 PM
Message :which cylinder is bad - getting the plug undone can either be hard or real hard!!!
OK! by the way when i pulled the ignition coil for the one i circled in the photo below it came out in pieces... the other ones are fine... although i dont know where the ignition coil for the cylinder closest to the driver is... im sure its the ignition coil...
