TwinTurbo.NET: Nissan 300ZX forum - Re: Definately AFM.......
Subject Re: Definately AFM.......
Posted by Snowmansdsm09 on February 25, 2010 at 11:24 PM
  This message has been viewed 115 times.
In Reply To Definately AFM....... posted by zx299 on February 25, 2010 at 05:43 AM
Message If you say you have tried 2 known good MAF's, then you need to
move on to looking for corrosion at connector, then ground
resistance, voltage of power wires, then lastly disconnect ECU
connector and ohm test all MAF wires that end at the ECU
connector.
Corrosion should be first suspect on the Z's when you have
sensor issues...the end.
