TwinTurbo.NET: Nissan 300ZX forum - There is an easy way to check if the turbos are working;
Subject There is an easy way to check if the turbos are working;
Posted by Machtavian on February 25, 2010 at 5:26 PM
  This message has been viewed 272 times.
In Reply To turbos dont spool posted by 300fairlady on February 25, 2010 at 02:43 PM
Message pull off the the hose thats coming from the turbo outlet while the car is
running, give it some gas from the throttle cable on the plenum to make
sure it doesn't die. You should be able to feel air being blown out like a
dryer. If you don't feel air then your turbos aren't working. check both
sides individually.
