TwinTurbo.NET: Nissan 300ZX forum - This should be in the technical forum. Do you feel any
Subject This should be in the technical forum. Do you feel any
Posted by Haasz32 on February 25, 2010 at 2:55 PM
  This message has been viewed 192 times.
In Reply To turbos dont spool posted by 300fairlady on February 25, 2010 at 02:43 PM
Message boost come on at around 3500 rpm under acceleration? I'm guessing you don't, but just wanted to make sure. It's possible you're making boost but your gauge is not working properly. Those factory boost guages are highly inaccurate. Although they typically show positive manifold pressure under boost.
How does your engine run (at idle or under load)? If it's running crappy, you could have a vacuum leak. Or there's the possibility as you suggested that there's a problem within the turbos themselves. My point is that we need more info.
