TwinTurbo.NET: Nissan 300ZX forum - The front will be fine depending on the tire you run
Subject The front will be fine depending on the tire you run
Posted by KevinZtwin on February 25, 2010 at 3:30 PM
  This message has been viewed 66 times.
In Reply To Can I fit 17x9 +45 on the front and the back? posted by Paulym1111 on February 25, 2010 at 01:16 PM
Message With a 9" +45 offset you are very close to hitting inner suspension components at full wheel turn. You essentially have 3mm more clearance than I did with my track wheels (which barely rubbed at full lock, so I put a 5mm spacer in the front).
I think you will be fine
353rwhp, 381rwtq, 91 pump, 15psi
