TwinTurbo.NET: Nissan 300ZX forum - I agree with above, MAF...(more)
Subject I agree with above, MAF...(more)
Posted by Snowmansdsm09 on February 25, 2010 at 12:17 AM
  This message has been viewed 152 times.
In Reply To My car won't go past 2500 RPM posted by texasman80 on February 24, 2010 at 02:29 PM
Message I had the same problem, and is the reason I bought my car so
cheap. The guy couldn't figure it out.
So I set out to see if it was a major boost leak or the MAF
sensor.
I fixed all boost leaks and then bought a new MAF, the MAF
sensor fixed the issue.
If you have already tried known good MAF sensors, then i
would next make sure the terminals on the connector going to
the MAF is free of corrosion. Then check ground resistance,
and resistance from MAF connector to ECU connector.
But this issue is a classic MAF symptom!
