TwinTurbo.NET: Nissan 300ZX forum - They will run w/out MAF, but barely....
Subject They will run w/out MAF, but barely....
Posted by ZXoltan on February 24, 2010 at 3:11 PM
  This message has been viewed 97 times.
In Reply To Re: It will run without the maf hooked up. posted by texasman80 on February 24, 2010 at 02:49 PM
Message Check the connector/ wiring to the MAF for corrosion or an open circuit.
Same thing can happen with a severe boost leak-- essentially the air taken in is not being metered so the symptoms are identical. Check for an IC hose that may have come loose, esp if this began right after you boosted.
