TwinTurbo.NET: Nissan 300ZX forum - In addition to possible cool temp sensor I would look >>>
Subject In addition to possible cool temp sensor I would look >>>
Posted by ZUL8TR on February 24, 2010 at 9:11 AM
  This message has been viewed 186 times.
In Reply To Idle air control valve?? posted by 91ttzx on February 23, 2010 at 07:39 AM
Message into checking and cleaning the IAA system
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=920429 ]
For idle issues
[ http://home.swipnet.se/e-solutions/ ]
Also:
Clean the throttle bodies and calibrate the throttle body linkage.
Check PCVs and replace if in there a long time. Only use OEM hoses and valves.
Look for small vacuum leaks.
Check as many connectors as possible especiall the IAA and injectors and cool temp sensor for corrosion, clean and fill with dielectric grease
ZUL8TR in Orlando,FL
