TwinTurbo.NET: Nissan 300ZX forum - Re: Major problem?...or easy fix...need help...
Subject Re: Major problem?...or easy fix...need help...
Posted by WazTTed on February 23, 2010 at 7:25 PM
  This message has been viewed 109 times.
In Reply To Major problem?...or easy fix...need help... posted by ZkillS on February 23, 2010 at 07:15 PM
Message are you sure that your lines are hooked up correctly. the line you have circled is a coolant line. there is a identical one on the opposite side ... if its leaking it should be spewing green coolant...
the only oil feed is a tiny hose right on the top of the CHRA.. and the large pipe that goes 2 the sump is the oil return
