TwinTurbo.NET: Nissan 300ZX forum - Re: Major problem?...or easy fix...need help...
Ibn Z(VA)
on February 23, 2010 at 7:25 PM
posted by ZkillS
on February 23, 2010 at 07:15 PM
The banjo bolts that you talking about has coolant running through them. The oil line is attached at the top of the turbo. Maybe the oil line is loose and it's running down the sides making it appear its coming from the banjo bolts.
ZkillS
19:15:56 02/23/10
Re: Major problem?...or easy fix...need help... -
Ibn Z(VA)
19:25:10 02/23/10
Re: Re: Major problem?...or easy fix...need help...
ZkillS
19:32:18 02/23/10
Re: Re: Re: Major problem?...or easy fix...need help...
WazTTed
20:16:14 02/23/10
WazTTed
19:25:44 02/23/10
i had the same problem its the oil line in top of the turbo
Zboy17
09:17:25 02/24/10
