TwinTurbo.NET: Nissan 300ZX forum - AIV mid-pipe delete
Subject AIV mid-pipe delete
Posted by JUNz (?00)rwhp on February 23, 2010 at 3:29 AM
  This message has been viewed 278 times.
Message If you take a closer look you can see i was unable to remove the pipe and nut from the Pass.side midpipe. Drive-side completely removed.
After torching it, pb blast, 23-24 box wrench and vise grips the nut was so stripped i cut the pipe and nut off.
1) should i get a bolt welded into the remaining pipe/nut and try to remove the resst of it?
2) should i JB weld or weld up both sides closed
Thanks.
