TwinTurbo.NET: Nissan 300ZX forum - If this is a used car I would really do more then a oil and
Subject If this is a used car I would really do more then a oil and
Posted by 5280Z_nightstalker on February 21, 2010 at 11:23 PM
  This message has been viewed 94 times.
In Reply To Twin turbo hasnt been started in 5 yrs posted by Randro79 on February 21, 2010 at 09:06 PM
Message plug change. I would change the PCV valves, do a boost leak test, compression test (for piece of mind), and OHM the injectors and TPS atleast. It sounds like a boost leak which could mean a hose is not plugged and the boostleak test will help you find this. I hope that helps but on a used car like this there is a lot of work that is needed to make it run like a champ again
Good luck
"Do you guys put the key in "balls down", or up?" -BobbyT 10:28:19 03/06/09
tt.net
