TwinTurbo.NET: Nissan 300ZX forum - Get under the car and have someone work the clutch.
Subject Get under the car and have someone work the clutch.
Posted by Gordo 93TT Daytona on February 21, 2010 at 7:00 PM
  This message has been viewed 117 times.
In Reply To You might have a problem at the pivot ball of the fork>> posted by ZUL8TR on February 21, 2010 at 06:52 AM
Message See if the slave piston is actuating the clutch fork. It needs to move at least an inch or two. If it is, then problem is inside the the bell housing with pivot ball, fork or clutch itself. If the slave piston travel is less than an inch, then you have problems with the hydraulics, mostly likely air in the line. Rebleed carefully. If problems persist, the air leaks might be caused by a leaking slave cylinder. Could be master, but usually slave goes first.
_________________________________________________
