TwinTurbo.NET: Nissan 300ZX forum - fluid leak at slave and/or master at shaft. Look >>
Subject fluid leak at slave and/or master at shaft. Look >>
Posted by ZUL8TR on February 21, 2010 at 9:51 AM
  This message has been viewed 103 times.
In Reply To Clutch question. posted by not-hrz on February 20, 2010 at 05:21 PM
Message at slave for signs of leak as mkspriggs noted and have someone press the clutch to see if leak occurs under pressure. If slave ok look at master for leak at shaft that goes thru the firewall. There is a boot there that will fill up if shaft seal leaking and fluid will eventually leak out on the inside of the firewall behind the insulating material under the rug.
ZUL8TR in Orlando,FL
