TwinTurbo.NET: Nissan 300ZX forum - Here's what I found on my zeitronix sensor...
Subject Here's what I found on my zeitronix sensor...
Posted by Wright (Ca) on February 19, 2010 at 10:23 PM
  This message has been viewed 1231 times.
In Reply To Yes, i got the info from the zeitronix website. posted by hijack on February 19, 2010 at 01:18 PM
Message Found printed on the side of the sensor:
P255-50A-E4A
A little google searching turned up this pdf:
sensor
The code would indicate that the sensor:
-Has a pressure range of 0-50psi
-Reference = Absolute
-Seal Material = Fluorosilicone
-Pressure Connection = 1/8-27 NPT
-And has a electrical connection type: Mating connector, w/12”, 18 AWG leads
Most importantly it states that it has a linear amplified output and that at 0psi voltage will be 0.50 ±0.08 Vdc,
Full Pressure(50psi in my case): 4.50 ±0.08 Vdc.
The zeitronix unit should be able to interpret your map sensor if it has these same voltage/pressure characteristics. I believe the zeitronix unit can also be configured to be used with a 0-75 psi sensor.
Take a look at your sensor and see if it has any numbers that we can look up.
Formerly: ZEVAN (Ca), Evan3zx(ca)
Xbox live GT: kidding Me
1991 CRP TT
1993 Pearl White NA
