TwinTurbo.NET: Nissan 300ZX forum - Re: Dip stick blow out?
Subject Re: Dip stick blow out?
Posted by street kingz on February 19, 2010 at 7:48 PM
  This message has been viewed 341 times.
In Reply To Dip stick blow out? posted by Z-tarded on February 19, 2010 at 04:48 PM
Message :Has anyone ever experienced the oil dip-stick being pushed up out of the holder? I smelled some burning oil today under the hood and saw a minor amount of oil splattered on the dipstick side of the engine. Also noted the dip stick out a couple inches or so from its sleeve. I put it back in after checking the level and cleaning off the splattered oil. I gave the underside a visual, and when I was certain there was no drastic leak I drove the car several miles, rechecked it and no oil anywhere, level fine, pressure fine, temp fine, dipstick in place. Can that happen when you get on the accelerator hard??
I had the same issue two weeks ago, I changed PCV, still would pop out, turned down the boost, 12psi still would pop out. the fix turned out to be to get a new DipStick. I would buy a new Dipstick since it is not that exp.. Just my 2 cents.. Good Luck...
