TwinTurbo.NET: Nissan 300ZX forum - If you want to test for VTC noise, the only real test is
Subject If you want to test for VTC noise, the only real test is
Posted by LitlElvis on February 19, 2010 at 11:41 AM
  This message has been viewed 299 times.
In Reply To Intake Sprockets posted by ZXRider on February 19, 2010 at 05:07 AM
Message while the engine is idling (and the VTC are presumably making noise) activate the VTC by grounding the green with black stripe wires that go to the solenoids. If the noise goes away, the VTC are the culprit(s), if not look elsewhere.
If you think they may be the source of an oil leak, you will need to remove them so you can grab the rear plate and see if it spins. Using a rubber glove on your hand will help get enough grip on the cam seal plate. If it spins by hand, the o-ring is likely shot and leaking oil, if not, it's just a matter of time :-)
