TwinTurbo.NET: Nissan 300ZX forum - He should be able to swap over the base engine w/out
Subject He should be able to swap over the base engine w/out
Posted by jzack on February 18, 2010 at 7:45 PM
  This message has been viewed 184 times.
In Reply To Wrong motor posted by Stadsport (PHX) on February 18, 2010 at 09:54 AM
Message any issues - but would be a good thing to double check someplace like the Hybrid Z forum.
Would think you could re-use all the control electronics from the old engine and swap some brackets and such that are made for the Z. There would also be an issue with the injectors -- since the ones used in the old engine have a different sized electrical connector (need to splice in connectors made for the '96 engine injector). Old engine injectors also won't fit the '96 engine's lower plenum.
Should be no issue running w/out the VTC's solenoids either - doesn't cause any issues running with them disconnected on Z's today. You just don't get that extra bit of performance...
