TwinTurbo.NET: Nissan 300ZX forum - help!! j30 motor into 300zx problems
Subject help!! j30 motor into 300zx problems
Posted by stevec8720 on February 17, 2010 at 8:49 PM
  This message has been viewed 573 times.
Message ok i have a 93 300zx na and the timing belt jumped so my valves are bent. it has 180k on it and picked up a 96 j30 engine for it. the problem is the j30 motor has no vtc solenoids on it and now the question is how can i make it work do i need to swap camshafts or just the solenoids and cam gears or can i just drop it in without them and leave the system unplugged?? if the vtc dosent work thats ok but i wanna make sure it will run ok. is the cams on a 96 j30 the same as a 93 300zx cause if they are i would imagine i could just swap the solenoids and cam gears right? please help i cant continue any further without knowing what to do
