TwinTurbo.NET: Nissan 300ZX forum - Those with wideband O2s, where to tap +v and ground ?
Subject Those with wideband O2s, where to tap +v and ground ?
Posted by TTkeeper on February 17, 2010 at 7:56 PM
  This message has been viewed 170 times.
Message Do most wideband O2 kits recommend tapping the +12v and ground that the ECU shares ? Which pins, wires, or connection points are easiest to get at ? Is there enough
current on that circuit to power 2 wideband sensors & gauges...or should the sensors be powered off a higher amp circuit ?
