TwinTurbo.NET: Nissan 300ZX forum - The white lines on the timing belt are only for initial>>>
Subject The white lines on the timing belt are only for initial>>>
Posted by ZUL8TR on February 17, 2010 at 12:33 PM
  This message has been viewed 135 times.
In Reply To I would agree. If you are getting strange readings with posted by Audioquest on February 17, 2010 at 10:40 AM
Message install of belt for conveinent teeth count and offer no use for checking the proper timing of the belt. The important marks are the dimples on the 4 cam pullies and the crank pully lining up with the permanent marks on the backing plate at TDC of the # 1 cylindere on the compression stroke.
ZUL8TR in Orlando,FL
