TwinTurbo.NET: Nissan 300ZX forum - Only way to know for sure on the belt is to pull the
Subject Only way to know for sure on the belt is to pull the
Posted by jzack on February 16, 2010 at 7:09 PM
  This message has been viewed 108 times.
In Reply To Re: The CP connector wire harness is what I use and my posted by ZPUHost on February 16, 2010 at 05:15 PM
Message t-belt covers and count the teeth between the CAM marks and the crank sprocket mark. It's a big pain in the ass to do - so I'd suggest making sure your timing test is being done accurately first. You've already started/run the car -- so it's not like you'll be causing any (more) damage to the engine if the t-belt setup is not right....
Why don't you try the light on another car - just to confirm it's working OK?
