TwinTurbo.NET: Nissan 300ZX forum - Re: The CP connector wire harness is what I use and my
Subject Re: The CP connector wire harness is what I use and my
Posted by ZPUHost on February 16, 2010 at 5:15 PM
  This message has been viewed 129 times.
In Reply To The CP connector wire harness is what I use and my posted by Audioquest on February 16, 2010 at 08:58 AM
Message The timing light pulses and seems to be working just fine using the loop wire. I don't have a spark plug extention to remove the coil pack and run it from cyl 1.
Its possible it jumped a tooth is there any other foolproof way to test the timing?
The CAS does move the mark around but its still FAR FAR FAR off from where it should be. Should i just go and replace the belt and reset the timing as per the factory spec?
