TwinTurbo.NET: Nissan 300ZX forum - Just one note.
Subject Just one note.
Posted by DVDBURN (MD) on February 16, 2010 at 1:33 PM
  This message has been viewed 423 times.
In Reply To VTF 90-95 ECU Connector pinout posted by aliaZ on February 16, 2010 at 10:13 AM
Message When checking injector resistance in a 1995 you must either check the resistance between pin 45 and the injector pins or use pin 58 while the key is in the ON position. In both cases you must disconnect the battery first and for accuracy in measurement you must remove the connector from the ECU (10mm bolt). Good injector resistance should be close to 12 ohms.
www.mytwinturbo.com
Watch an ECZA meet caravan!
Download my Nissan 300ZX Vin/Model Lookup
