TwinTurbo.NET: Nissan 300ZX forum - 2nd. that's the only way my timing light picks it up. (n/m)
KasbeKZ(VA)
on February 16, 2010 at 8:40 AM
My car has an underhood OEM sticker showing that >>>
posted by ZUL8TR
on February 16, 2010 at 06:29 AM
timing woe's
ZPUHost
20:44:29 02/15/10
Re-check using the coil pack wires going to cylinder
jzack
22:42:20 02/15/10
ZUL8TR
06:29:35 02/16/10
2nd. that's the only way my timing light picks it up. (n/m) -
KasbeKZ(VA)
08:40:08 02/16/10
The CP connector wire harness is what I use and my
Audioquest
08:58:40 02/16/10
Re: The CP connector wire harness is what I use and my
ZPUHost
17:15:02 02/16/10
Only way to know for sure on the belt is to pull the
jzack
19:09:42 02/16/10
Try the procedure I suggest above B4 anything major (n/m)
ZUL8TR
06:02:34 02/17/10
I would agree. If you are getting strange readings with
Audioquest
10:40:25 02/17/10
The white lines on the timing belt are only for initial>>>
ZUL8TR
12:33:44 02/17/10
The white lines are meant to line up with the dimples on
Audioquest
08:53:13 02/18/10
Of course the number of teeth between the marks on the >>l
ZUL8TR
11:17:13 02/18/10
Yeah, that's all I was getting at. A lot of people try to
Audioquest
11:58:28 02/18/10
Re: Yeah, that's all I was getting at. A lot of people try to
ZPUHost
23:46:07 02/20/10
