TwinTurbo.NET: Nissan 300ZX forum - Here's an option
Subject Here's an option
Posted by Spddracer on February 15, 2010 at 6:59 PM
  This message has been viewed 134 times.
In Reply To Turbo wastegate issue, need opinons. posted by Woody75 (Denver) on February 15, 2010 at 05:04 PM
Message One of my stockers came back that way from the rebuild.
I don't know if it got dropped, heat let the arm bend, Welded back together wrong or what.
I simply and carefully put the waste gate arm, The metal flat steel on the side you show, in a vice. Twist the turbo and basically bend the arm back to where it should be. Of course this could risk breaking it but it worked for mine as it would not work well the way it was and really didn't see another option.
I guess one could grind the arm off the shaft and re weld in the correct position also.
Zspeedperformance.com
