TwinTurbo.NET: Nissan 300ZX forum - Turbo wastegate issue, need opinons.
Subject Turbo wastegate issue, need opinons.
Posted by Woody75 (Denver) on February 15, 2010 at 5:04 PM
  This message has been viewed 356 times.
Message Installing some turbos for a customer and see a possible issue. These are used AMS stage 2 turbos from what he told me. I noticed the allignment of the rod on the drivers side was almost straight to the wastegate flapper arm. Normally you see a bit of an angle. So I hooked up an air source to see how well it would work. It doesn't seem to open very far at all. I checked the passenger side as well and it does the same thing. Then I compared them to the stock turbos I took off and there a large difference.
Here is the drivers side AMS:
closed
open to max
closed
open
Stock drivers side for comparison:
closed
open
Passenger side AMS (even less range):
closed
open
Stock passenger side for comparison:
closed
open
Is this enough of an issue to worry about? They appear to use stock wastegates with modified arms. But I don't think bolting on the old stockers will work correctly as the rods are different lengths and the position of the wastegate flapper is in different postions too. Would it be worth it to get upgraded wastegates with adjustable rods (Forge, HKS, etc) and modify the flapper mount at the same time so the angle is better? Or jsut throw on the stock watestgates and modify just the flapper mount position? Let me know what you think. I'll have to talk it over with the owner and see what he wants to do in the end. Thanks for any help.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
