TwinTurbo.NET: Nissan 300ZX forum - 2nd.....You're firing the coil constantly
Subject 2nd.....You're firing the coil constantly
Posted by BOOZTD 3 on February 15, 2010 at 1:32 AM
  This message has been viewed 109 times.
In Reply To Re: I keep melting number 1 coil pack??? posted by txq45 on February 14, 2010 at 08:50 PM
Message Do a voltage check on the next coil pack harness. You likely have the constant 12V and the trigger wire swapped.....causing the coil to fire constantly. This should be evident when the car is cold, and you turn the ignition on, and within a minute or so, the coil is warm, if not hot already
