TwinTurbo.NET: Nissan 300ZX forum - I also used a nipple from the balance tube and had no issue.
Subject I also used a nipple from the balance tube and had no issue.
Posted by Dark Diver on February 14, 2010 at 1:15 PM
In Reply To signal should be between compressor outless and pre throttle posted by Dane (Houston) on February 13, 2010 at 11:55 PM
Message "as you have it routed to the balance bar you are sending a
constant vacuum signal to the wastegate when not boosting."
When not boosting the EBC's solenoid is closed and WG's
actuators won't see vacuum.
