TwinTurbo.NET: Nissan 300ZX forum - First I would use RTV that has the highest heat and >>
Subject First I would use RTV that has the highest heat and >>
Posted by ZUL8TR on February 14, 2010 at 11:28 AM
  This message has been viewed 148 times.
In Reply To Post Plenum Pull need help lost all my oil driving 20 miles posted by wolftg on February 14, 2010 at 10:44 AM
Message oil resistance that Permatex has. Then really clean the surfaces to seal with laquer thinner. AS far as the plenum gasket use only the OEM with the seal side down. Make sure all surfaces clamp down to their full close position.
Can't say what you did wrong cause not able to inspect the results and wasn't there when you did the work.
ZUL8TR in Orlando,FL
