TwinTurbo.NET: Nissan 300ZX forum - signal should be between compressor outless and pre throttle
Subject signal should be between compressor outless and pre throttle
Posted by Dane (Houston) on February 13, 2010 at 11:55 PM
  This message has been viewed 253 times.
In Reply To Re: Re: Blow another hks 2530 in 300 miles same side posted by 94ttz32 on February 13, 2010 at 11:15 PM
Message bodies. plenum signal is incorrect. The singal source you want is where bootjets would be placed, which is the on the inside intercooler pipes for example:
[ http://jimwolftechnology.com/wolfpdf/Z32TTBOOSTJETINST.PDF ]
as you have it routed to the balance bar you are sending a constant vacuum signal to the wastegate when not boosting. as pressure is very low after the throttle bodies, these low pressure (vacuum) are not on pre throttle body side. I dont know if this could or not cause wastegate damage or issues.
if using EBC plenum signal is for EBCs electronic sensor. then the control solenoids input is between compressor and pre throttle body, the solenoid output goes to the wastegate accuator
Formerly SpecNATT (Houston)
