TwinTurbo.NET: Nissan 300ZX forum - The failure point is the hydraulic tensioner itself.
Subject The failure point is the hydraulic tensioner itself.
Posted by Spddracer on February 13, 2010 at 7:48 AM
  This message has been viewed 540 times.
In Reply To Typical failure point when a timing belt tensioner breaks? posted by EUGENE on February 13, 2010 at 04:32 AM
Message I would reuse the old base and use everything else off the new one. Just replace the broken arm with the old one.
You must close them very slowly as you found out. There is normally no reason to even mess with the adjustment bolt if they are new as they are set were they need to be most of the time.
Zspeedperformance.com
