TwinTurbo.NET: Nissan 300ZX forum - tech help
Subject tech help
Posted by frankd_13 on February 10, 2010 at 10:35 PM
  This message has been viewed 112 times.
In Reply To need a little help? posted by gman300zxtt on February 10, 2010 at 01:24 AM
Message what you want to do is check cranking voltage on the connecter.if you think its a dead coilpack, what you want to do is have the car running. one by one disconnect each coil. if if its starts to ideal bad. then that coil is good. keep going until you get to the one that will not change idle. you will also need a noid light to test injector sig. you will have to take off the fuel pump relay and check cranking pulse.
