TwinTurbo.NET: Nissan 300ZX forum - Leaking Brake Master Cylinder
Subject Leaking Brake Master Cylinder
Posted by enthuZiast on February 10, 2010 at 3:08 PM
  This message has been viewed 445 times.
Message As stated above, brake fluid seems to be leaking between the reservoir and master cylinder unit. When the reservoir is slightly tilted side to side (driver to passenger) bubbles are seen seeping past the rubber gasket/o-ring where the reservoir is "plugged" into the aluminum master cylinder unit.
Brake pressure is low and the reservoir requires refilling regularly as fluid escapes through the rubber gasket/o-ring.
Is there a rebuild kit to replace the gasket between the reservoir and master cylinder or is replacement of the entire Brake Master Cylinder the only fix?
TIA.
src="http://www.streetneeds.com/uploads/twinturbonet/CIMG0427_021008
.JPG">
<<< Slow in & Fast out >>>
