TwinTurbo.NET: Nissan 300ZX forum - Recheck if any looseness at the alt wires on the back >>
Subject Recheck if any looseness at the alt wires on the back >>
Posted by ZUL8TR on February 10, 2010 at 8:15 AM
  This message has been viewed 157 times.
In Reply To strange voltage reading after alternator replacement posted by jamil on February 09, 2010 at 09:25 PM
Message especially the small ground and the plug in connector. I use dielectric grease on the plug in.
Did you have Autozone check the new alt on the bench to make sure it passed?
I will add that I recently replaced the alt 3 times due to faulty units that the dioeds failed, These were Pep Boys alts and all were checked B4 I left the store. I fiannly gave up and picked up an alt at a local reputable rebuilder (using a no charge exchange from Pep Boys they were very cooperative). That unit is many monts old and works fine.
BTW with this alt issue and drive on ramps I can pull and replace an alt in 45 minutes - big deal still a PITA and not worth knowing unless in the auto repair business.
ZUL8TR in Orlando,FL
