TwinTurbo.NET: Nissan 300ZX forum - The holes start from the bottom for placement purposes.
Subject The holes start from the bottom for placement purposes.
Posted by ZiNnYc on February 08, 2010 at 8:58 PM
  This message has been viewed 58 times.
In Reply To Stillen rear strut bar installation on a 2+2 posted by Zxtec on February 04, 2010 at 08:46 PM
Message After you install the bar, you need to
place the panels back, and they need to
slip over the bar, hence the opening
from the bottom to where it stops
"entering" the panel. You can do what I
did for a slightly stealthier look and
simply dremel a line to where the bar
will actually sit, and that's where you
actually cut a hole for the strut bar.
Then, you bend the panel, slip it over
the bar, and it'll fit exactly where you
made you hole opening. It will require
some finesse and
planning/measurements, and it's
obviously WAY easier to do it with large
gaping holes like everyone else, but it's
visually appealing and superior to do it
this way. Call me if you need some
clarification.
btw, the Powertrix 1-pc bar is superior
to the Stillen. It's lighter, less intrusive,
and available in a stealth black design.
The Stillen bar is just so huge, always
looked ugly to me, especially with those
holes.
