TwinTurbo.NET: Nissan 300ZX forum - the great ENG CONT fuse blowing problem....
Subject the great ENG CONT fuse blowing problem....
Posted by ZkillS on February 07, 2010 at 9:58 PM
  This message has been viewed 1095 times.
Message Ok, ive been searching all day on this, and ive noticed alot of posts say check the O2 sensors, but that seems to be when their car is running rough. MY PROBLEM is... Just finished installing my engine 91 TT and tried starting. Turned over great, but would not start. Ran the Ecu test. told me the CAS was bad, got another CAS and replaced it. Finally got fire at the plugs and heard the clicking from the injectors. So im slowly moving along. BUT that dang ENG CONT fuse keeps blowing the SECOND i turn the key on, imedietly. I still havent had any luck starting the car. Would this fuse be causing it to not start? and if so what would cause it to blow so quick especially since it hasnt even ran yet. BTW ecu test gives me 55 no problem found. BUT that fuse keeps blowing. Hope someone has a lil helpful information.
