TwinTurbo.NET: Nissan 300ZX forum - Re: Z won't turn over!!!!
Subject Re: Z won't turn over!!!!
Posted by Stpdfast Z on February 06, 2010 at 5:30 PM
  This message has been viewed 158 times.
In Reply To Z won't turn over!!!! posted by TTZ2NV(TX) on February 05, 2010 at 02:43 PM
Message You starter relay is in the front left wheel well behind the splash guard close to the firewall. You can only access it from outside the car. Do a search and it will explain how to bypass it and see if your car starts. You can put a meter on it and see if it checks good or not. You can also check your fusable links in front of the battery and make sure one is not blown.
